just wondering what options is out there ...
i've seen mocal and tilton, but want to hear people's personal experiences on what is good and bad
those 2 brands seem to be made of plastic whilst there is one on ebay which has brass internals
any discussion would be much appreciated!
You get what you pay for.
I use tilton pumps and have never had any problems with them. I did a fit out for a GTR recently using 4 of them (2x diffs, transfer and hollinger transmission).
They are not cheap but well worth the money.
The ones I'm using are far from plastic, the pump section is machined alloy with tools steel gears and the motor section is steel.
You want to use a pump that has a separate pump section which is sealed from the motor, tool steel gears and then decide if you want a constant flow pump or a triggered pump (they are different motor sections) triggered pumps has a capacitor start feature so they don't draw all the current away from ecu, injectors etc when they turn on and off constantly.
You want the oil sealed from the motor for a few reasons.
Less heat around the comuntator, brushes etc.
No chance of worn comuntator, brush etc getting into the diff oil
Serviceability you can replace parts not a whole unit
Tool steel gears are a bit noisier but there is massive amount of wear with brass gears which leaves brass in the diff oil.
Tool steel gears will probably outlast the car unless they ingest something.
hey brad!
thanks for that info!
do you know the model number of the pumps you use?
coz theres three models that tilton sell.
this is what tilton emailed me:
Pump P/N 40-527 is similiar to P/N 40-524, excpet for it has a continous duty motor. The pump head is plastic and the diaphragm is Buna rubber.
thats what i meant by plastic bits
I'll check on Monday and let you know.
Have you done any data logging to determine if you need a pump/cooler system?
hey brad!
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
