sooo, becuase i cant update the price and other things the first post on my other thread for this car i am posting another one.
to see photos please see this thread:
http://www.skylinesaustralia.com/forums/topic/377889-s2-stagea-rs4-neo-gtr-s-z32-nistune/page__fromsearch__1
Series 2 Stagea C34 RS4, Built 2000
Rego until Jul-2012
Silver in Colour
Driven daily by my wife with the kids
Last dyno was at 255hp at the rear wheels. Has now been fitted with z32 and nistune since then. I have a tune on there that was on another stagea tuned for 14psi.
No accident history
Location – Ipswich, QLD
Price - $12,500 ono ( i am Negotiable , so ring me or email me and i'll get back to you )
No Time Waster Please - Serious Buyers Only
Contact – Curt 0430 104 668 or [email protected]
Engine
· RB25DET Neo Engine with 122,xxxks
· 100k service done
· Greddy Blow off Valve in stock position
· HPI FMIC from Just Jap with Stainless Piping
· Full HKS GTRS Turbo kit with stainless braded lines
· Z32 AFM
· Apexi Air Filter
· Malpassi Fuel pressure regulator
· 500hp Walbro intank fuel pump
· HKS Dump pipe with custom intermediate pipe
· 3" x-Force cat
· 3" Apexi silent power II cat back exhaust
· Just serviced with Penrite HPR15 oil
Drivetrain
· Gearbox valve body has been upgraded to stage 3. (very nice and smooth to drive in Auto mode, whilst in tiptronic it shifts quick and tightly.)
· Semi Auto Tipronic
· R33 GTS-T 4pot front and 2pot rear Calipers Fitted (rear Stainless Braided lines fitted aswell)
· Brand new Slotted rotors fitted 18mths ago
· Tein super street suspension with adjustable ride height, dampening, and rebound. From Fulcrum
· Stagea Strut Brace Front
· New Swaybar links Fitted front
Exterior
· Custom towbar fitted.
· Avanti 18" wheels and tyres
· Clear Side Indicators
· LED parker Lights
· LED number plate lights
· Dual Sunroofs working perfectly and no leaking
· Tinted front Windows and Sunroofs
Interior
· Apexi Boost Gauge (in Bar )
· Apexi Turbo Timer
· Greddy Profec B II boost Controller (7psi and 14 psi settings)
· Nistune Programmable ECU with licensed software
· LED interior lights (great at night time)
· Air con works really well, new bulbs fitted to dash panel
· Stagea Floor Mats
· Still has Nissan Car Security that Still works, comes with funky remote for remote starting J
· Rear cargo cover (pull from behind seats to rear gate to cover item in the boot, leather)
https://www.sau.com.au/forums/topic/398181-s2-stagea-rs4-neo-gtr-s-z32-nistune/
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
