  • 4 weeks later...
  • Replies 151
  • 2 months later...
  • 3 weeks later...
HKB boss kit sold sorry.
This is what's left:
New parts
Mazda Air temp sensor (for PowerFC D-Jetro) (brand new) $120
S14 'Edge' Side skirts, unpainted white gelcoat (brand new) $250
S14.5 Origin +25mm conversion fenders (brand new) $450
S14 Origin +50mm rear fenders (brand new) $450
S14 light weight fibreglass doors (brand new) $900
S14 Full Lexan window kit (rear window with NACA vents, rear quarters, driver and passenger door windows with slider window kits) (brand new) $1,050
Used parts
Factory
S15 factory rear boot spoler with led's, pewter colour $120
S15 JDM factory steering wheel with airbag $230
S15 front factory fenders (metal) no damage, no repairs $250 each
S15 factory rear bar $50
S15 factory sway bars $80 the pair
S15 boot lid and ducktail spoiler (not separating, duck tail is sikaflex'd and bolted on to boot lid) $300
S14a rolling shell, 6 point welded roll cage, white. Interior getting painted fresh white before sale.
Aftermarket
Greddy engine oil cap $40
S15 Hybrid aluminium radiator $250
S15 c-west front bar $350
S14/S15 Nismo springs and struts (lower than factory, very comfortable on street) $550
S13/180sx TRUST 19 row oil cooler kit, thick quality trust core, for S13/180sx with filter relocator $600
HKS Super Sequential SQV BOV, genuine HKS, mounted on evo 8/9 hot pipe $300
ATP 'Frank' turbo, with stainless steel manifold, will fit s14/15 SR20det, good for around 240-250rwkw with stock cams. Braided lines included. $1100ono
C-west genuine carbon fibre GT-wing, mounted on matte black wrapped S15 boot lid $1,100
R34 GTR Cusco Type-40 aluminium strut tower brace $220
R34 GTR C-west N1 front bar (genuine), carbon fibre (painted black), will need respray/minor repairs $700
R34 GTR C-west carbon fibre cannards for N1 bar $350
R34 GTR/GTT Nismo GT LED tail lights $1,200
R34 GTR Alcon 6-pot front 365mm brake kit, 4-pot rear 330mm brake kit. Ferodo DS3000 pads all round $6800
RAYS LE37's Top Secret Limited Edition Gold 18 x 10.5 +15 all round (rare, don't really want to sell these) $4000
SSR Type-C 17 x 9.5 +15 PAIR ONLY, white, average condition for age, no buckles $1000
** can post wheels interstate if needed at buyers cost **
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
