Ive just put the engine back into the car and hooked everything up, installed a 040 pump. Car wont start, the pump primes but theres no fuel going into the hoses, i disconnected all hoses from the pump and they are dry, no fuel. Thought it might be the pump so i put the stock one back in and same thing. What could be causing it?
Have just installed:
Nistune
555 injectors
040 pump
Z32 afm
Could the ecu or afm be causing it?
Car is a r33 with s2 engine and has half a tank of fuel, pump is submerged so should be picking up fuel
Edited by lui
https://www.sau.com.au/forums/topic/398805-r33-wont-start-no-fuel/
Nistune
555 injectors
040 pump
Z32 afm
Check that you haven't reversed the polarity on the fuel pump. It will still prime, but it will be spinning in reverse.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
