R33 GTR COIL HARNESS, HKS DLI & HKS R33 GTR DLI HARNESS.
1. HKS DLI w/ Universal Harness
HKS Part No#: 43001-AK001
Perfect Condition, Not a Scratch on the DLI Box, Universal harness previously used.
Less than 1000kms use, one run in.
2. HKS R33 GTR Plug & Play Harness
HKS Part No#: 4399-SN002
Brand New.
3. R33 GTR Coil Harness
Nissan Part No#: 24079-24U10
Perfect Condition.
Pics: We all know what they look like but available on request to genuinely interested persons.
Asking $850 for the lot.
Contact via PM
More info:
Obviously comes with harness to suit R33 GTR but can be mated up with the following cars using the universal harness.
Upto 8 Outputs (Coilpacks).
Skyline - R32 GTR - BNR32
Skyline - R33 GTR - BCNR33
Silvia - PS13 (Red Top)
Silvia - S14 S1
Silvia - S14 S2
Impreza - GC8/GF8 Ver1-2
Impreza - GC8/GF8 Ver3-4
Impreza - GC8/GF8 Ver5-6
Supra JZA80 S1
Supra MKIII - JZA70
Skyline - R32 GTS-t - HCR32
Silvia - S13 (CA18DET)
EVO - CD9A
EVO II - CE9A
EVO III - CE9A
Mark II S2 - JZX100
Starlet - EP82
Starlet - EP91
Mark II S1 - JZX100
Fairlady - Z32
Supra JZA80-S2
Soarer - 2.5GT-T S1 - JZZ30
Soarer - 2.5GT-T S2 - JZZ30
Mark II - JZX90
Aristo - JZS147
Aristo - JZS161
Mark II - JZX81
Legacy - BD5 I
Legacy - BD5 II
Mark II - JZX110
GTO - Z16A
GTO - Z15A
THIS WILL NOT FIT;
Skyline - R33 GTS-t S2 - ECR33
Skyline - R33 GTS-t S1 - ECR33
Skyline - R34 GTR - BNR34
Skyline - R34 GTT - ER34
Stagea - 25t RS (~98+) - WGC34
Stagea - 25t RS Four (~98+) - WGNC34
Stagea - 25t RS Four (pre 98) - WGNC34
Stagea - 260RS - WGNC34
From what I can tell they are not made anymore (Well they are discontinued from Nengun)
Here is a little description:
"The Twin Power ignition amplifier incorporates both the CDI and transistor method ignition to provide optimum spark duration and maximum voltage output, resulting in crisper throttle response and a smoother engine powerband. The CDI method, capacity discharge ignition, provides maximum voltage by transferring all stored energy in the capacitor to the ignition coil so that the ignition current can buildup quickly, thus making the Twin Power very effective in the higher revs where a normal spark would tend to diminish. This strong rapid spark prevents the high rpm ignition miss that reduces peak power. The transistorized method generates high voltage by using transistors to cut off current to the coil, thus allowing for a long energy discharge. This longer spark duration allows the Twin Power to improve lower RPM throttle response and torque. The combination of the CDI and the transistor method incorporates two distinct systems into one high performance unit, hence the designation of Twin Power. The Twin Power produces a spark output that is typically 1.5-2.5 stronger than of the stock ignition system and consumes about 35% less power input than other ignition amplifiers.
The compact and attractive Twin power unit is constructed of durable anodized aluminum and sealed to prevent moisture corrosion. Universal wiring harnesses are included to aid in installation and mounting. Vehicle Specific wiring harnesses are also available for certain models for easier installation and to support installations that require complex integration.
Dimensions - All Twin Power Units, (except for DLI II), are 91mm (L) x 80mm(W) x 34.5mm (H) and weighs approximately 430g (~15.2oz)
Note: HKS Twin Power Units are not compatible with Non-Resistor Spark Plugs
Combination of transistor ignition type, which improves ignition at low rpm and CDI ignition, which improves ignition at high rpm increase ignition energy itself.
Latest vehicles even normal aspirated engines require spark plugs with higher heat range when intake and exhaust parts are upgraded. Twin Power enables strong spark to start engine and idling will be stable.
Cheers.
Edited by krayzie32
All 3 items are SOLD thanks guys.
Wont be responding to anymore PM's regarding this item.
Edited by krayzie32
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
