  • Replies 62
I have alot of other parts not listed so dont be scared to ask. Also if prices are steep im happy to negotiate. Also do bulk prices on several items. Sent lots of stuff to wa and sa so far, will post most items.
Will sell sunroof roof lining, light / switch, right or left rear body cut. aps pump unit thing. na steering rack and lines, na cross member, rear bar, aftermarket catback exhaust, 17" 4 stud wheels, Right or left tail light. Airbox with k&n filter + snorkle, green lable afm, na intake pipe from airbox to tb. Series 2 airbag steering wheel or airbag from dash.
Will take 900 firm for manual conversion. Its in the way!
Edited by coaster
bump, just bought another turbo wreck so will have bits off that soon. 5 stud hubs and brakes. rb25det manual conversion. huge garret highmount turbo with steam pipe manifold and external gate and custom exhaust. front radiator support, doors, heaps of gear.
Hi , i am interested in a full manual conversion kit for my R33 gtst series 2 ,
please let me know the price and also shipping cost to Victoria 3152 .
ta
hey mate. sent u a message. pm me if ur still interested.
  • 3 weeks later...
Do you have the front bumper liners? (Not the actual bumper) but the black plastic bits that attach to it and sit in the wheel arch... If you have both sides, and assuming you're willing to post to Perth, I will take them off your hands.
Please PM or sms me - 0401 549 030
Thanks,
Ben
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
