  • Replies 101
Hey Mate,
was wondering if the floor mates are still for sale and if they would fit a 4 door R34 GTT
also got any pics?
Cheers
Edit:
just read they are sold thanks
Edited by mcconnachie
Parts List Update
RB26DETT R32 (Powertune Built Motor) (10,000KM)
CP Forged Pistons (86.5mm)
HKS Camshafts 272 Degree, Lift 8.7, Step 1
HKS Cam Pulleys Duralumin
HKS Fine Tune Timing Belt
Splitfire Super Direct Ignition Coil Pack
NGK Iridium Spark Plugs
Cometic Metal Head Gasket
ARP Head Stud Kit
Bore & Hone Cylinder Block
ACL Race Series Conrod Bearing
ACL Race Series Main Bearing
Trust Greddy Clear Timing Belt Cover
$6500 SOLD!
Garret GT2860R-5 Turbos (10,000KM)
$1500 SOLD!
Sard 700cc - Set of 6 for BNR32,BCNR33,BNR34 RB26DETT Part # 63500 (10,000KM)
$550 Set SOLD!
Haltech Platinum Pro R32/R33 (Near New)
$1600 SOLD!
Trust Greddy Oil Filter Relocator
$150 SOLD!
Silicon Hose Kit (Black) (New)
$300
Nismo Fuel Pump (10,000KM)
$300 SOLD!
Tomei Sump Baffle Kit (New)
$200 SOLD!
R32 GTR Cusco Front Strut Brace
$150 SOLD!
R32 GTR Cusco Rear Strut Brace
$150 SOLD!
BOV Setup Including Stock Rb26 BOVs & Return Pipe
$200
R32 GTR Gearbox In Good Condition
$500 SOLD!
R32 GTR Tail Lights (Silver) (Just Been Resprayed With Car)
$50 Each SOLD!
R32 GTR Doors (Silver) (Just Been Resprayed With Car)
$200 Each
R32 GTR Side Mirrors (Silver) (Just Been Resprayed With Car)
$50 Each SOLD!
R32 Complete Dash With Vents No Bubbles (Very Hard To Find Without Bubbles)
$300 SOLD!
R32 GTR Rear Seat
$150
R32 GTR Rear Side Trims
$50 Each SOLD!
Tien HA Coilovers
$600 Set
R32 GTR Floor Mats (Set of 5)
$100 SOLD!
R32 GTR Carpet
$100
R32 GTR Rear Seatbelts With Bolts SOLD!
$70 SOLD!
R32 GTR Front & Rear Calipers
RDA Front & Rear Slotted Brake Rotors (15,000KM)
Bendix Front & Rear Ultimate Brake Pads (5,000KM)
$1200 The Lot SOLD!
GTR R324 Front End Conversion Kit (Genuine Kit)
R34 GTR Xenon Headlights
$900 SOLD!
R34 GTR Aluminium Bonnet (Just Been Resprayed With Car)
$950 SOLD!
R34 GTR Front Bumper Bar (Just Been Resprayed With Car)
R34 GTR Front Lip
R34 GTR Front Grill Badge
R34 GTR Front Indicators
$950
Bee*R R324 Type II Front Fenders (Just Been Resprayed With Car) (Genuine Bee*R From Japan)
$1500
Trust Style Rear Pods
$150 SOLD!
R32 GTR Boot Lid with R34 GTR Spoiler
$450
Custom Made Windscreen Washer Tank With Twin Washer Pumps Fitted
$150 SOLD!
R32 GTR Reverse Lights
$50 SOLD!
R32 GTR Speed Cluster Surround
$50 SOLD!
Nismo 600cc Purple Top Injectors
$600 Set SOLD!
HKS Fuel Rail 11mm RB26 R32/R33/R34 GTR
$290
Recaro Half Leather SR-Zero Bucket Seat (Driver Side) With Rail
$690
Powertune Custom Oil Catch Can / Radiator Reservoir Tank With Braided Hoses & Earl's Fittings
$590 SOLD!
Walbro 400 LPH In-Tank Fuel Pump & Universal Install Kit (New)
$190 SOLD!
Apexi Power FC R32/R33 GTR With Hand Controller
$790 SOLD!
Interested about these Coilovers
Firstly would u consider posting them? VIC 3429
what spring rate, is it damper and height adjustable?
Regards
PM Sent.
  • 3 weeks later...
  • 1 month later...
  • 3 months later...
Parts List Update
ARP Head Stud Kit
$6500 SOLD!
$1500 SOLD!
$550 Set SOLD!
$1600 SOLD!
$150 SOLD!
$300 SOLD!
$300 SOLD!
$200 SOLD!
$150 SOLD!
$150 SOLD!
$200
$500 SOLD!
$50 Each SOLD!
$200 Each
$50 Each SOLD!
$300 SOLD!
R32 GTR Rear Seat
$150
$50 Each SOLD!
Tien HA Coilovers
$600 Set SOLD!
$100 SOLD!
R32 GTR Carpet
$100
$70 SOLD!
$1200 The Lot SOLD!
$900 SOLD!
$950 SOLD!
R34 GTR Front Lip
$950
$1500 $1200
$150 SOLD!
$450 $350
$150 SOLD!
$50 SOLD!
$50 SOLD!
$600 Set SOLD!
$290 SOLD!
$650
$590 SOLD!
$190 SOLD!
$790 SOLD!
Edited by GTR ZOAH
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
