R32 interior sale
Passenger door card 20
L and R a piller trims 5 each
Bottom door trim with skyline on it L and R 5 each
Boot trim L and R side and boot carpet 10 each
Rear trim L and R 10 each
Climate control unit missing a button 15
Roof of glove box 5
Glove box 20
Metal bit that glove box hinges off 5
Bottom drivers dash bit 10 dash fuse box flap 5
Air induction thing under head light 10
Rear window bottom trim 5
Wiper arm with new wiper 10
Passenger door seal 10
Center dash surround 10
Chrome monza pod filter cover will make u win auto salon or apperntly pass a roady 1 dollar
L and R kick panel 10 each
Handbrake cover little worn no rips 5
6 bolt half shafts 10 each
Cover between glove box and passenger door 10
Centre air vent 20
33 centre console, may fit 32? 25
33 rear seat will fit 32 10 top 10 bottom
Manual tyre changer missing tyre lever 20
0430505810 DO NOT TXT phones cut off u will not get a reply, located emerald or montrose during business hours
https://www.sau.com.au/forums/topic/399937-r32-interior-bits/
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
