I've been looking for a new gear knob on ebay for my V35 350GT but i can't seem to find any that specifically say it will fit that car.
Just wondering if the 350z knobs would fit my car because i seem to be finding alot of those. 6 speed too.
Anyone that's purchased one for their 350gt let us know cheers
https://www.sau.com.au/forums/topic/399996-gear-knobs/
I've got the Tommy Kaira hebi bebi popular with the Z crowd. Shortens the shaft height because it mounts low on the stick if that's what you're after, probably not the choice for drifters tho :)
The low mounting height feels like it shortens the gate but due to it's 515 gram weight it maintains if not improves shifting effort.
https://www.sau.com.au/forums/topic/399996-gear-knobs/#findComment-6355045
  • 1 month later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
