Need abit of help choosing the right gear for my motor!
Its a RB30e r31 motor with roughly 140,000 kms on the clock
im after a turbo that would be appropriate for drifting , not after a lag monster, but nothing to small? possibly only want to run 14psi max im guessing for a standard motor with a new headgasket?
Also would i get away with drifting using a rb30 gearbox? or should i try and chase up a rb25 box or VL turbo box?
And would it be worth throwing a cam in it?
Sorry in advance if this isn't the correct forum for my questions, and thanks to anyone who has help on this topic!
cheers,
https://www.sau.com.au/forums/topic/400051-rb30et/
I have a 25 neodet motor coming my way next week >.> it only comes with a engine loom and computer, if i wire up a push button start system, with battery and indevidual fuel pump switch, should i be able to start the motor with just the wiring that goes with the engine??
https://www.sau.com.au/forums/topic/400051-rb30et/#findComment-6356309
Yes, but you will have some fault codes. TCS/ABS at the very least. If you do not have the (ECU, not dash) boost sensor plugged into the engine loom, then a code for that too.
https://www.sau.com.au/forums/topic/400051-rb30et/#findComment-6356912
No. Not that simple. Boost sensor is easy. TCS system is a whole 'nother story. The TCS system has its own computer that reads the wheel speed sensors and actuates the TCS throttle butterfly (upstream of the engine's normal throttle). The TCS butterfly has a position sensor on it.
When you start the R34 engine up, the engine ECU looks to see if the TCS system drives the TCS butterfly closed then open (start up self check). If it does not see that, it raises a code. Also, if the TCS computer is not present, then the ECU will raise a fault code because of the comms failure. You can only have it all work if you have a functioning TCS computer, which will probably raise fault codes of it's own if you don't have all the wheel speed sensors etc.
You can use a Nistuned ECU with a Stagea image in it (no TCS in Stageas) but my recent experience with doing so is that the automatic transmission Stagea images that are available cause driveability problems with manual Neo cars.
https://www.sau.com.au/forums/topic/400051-rb30et/#findComment-6358692
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
