Hey,
Long time lurker here on SAU...
Finally picked up my own Skyline yesterday, a black R32 GTR.
Will have picks soon, need to find some daylight!
Just a question out of curiousity..
It has HKS coilovers, I am looking at purchasing a coilover wrench to adjust them.
To lower it, do I need to take the coilovers out or can it be done from the engine bay/boot?
Pretty new to coilovers usually only had springs/shocks in previous cars!
Thanks
Edited by ls128
https://www.sau.com.au/forums/topic/400642-new-to-sau/
So they aren't just adjustable from the strut top (i.e engine bay or boot?)
I don't really have the knowledge to take coilovers out without f###ing something up!!!
I forgot to mention theyre HKS Coilovers
from the top, the adjustments will be just to dampener settings.
Taking the coilys out is surprisingly easy; I surprised myself when I swapped mine over that I didn't f**k it up :P Basically you jack the corner up and put it on stands, take the wheel off, and there's one big bolt that holds the bottom of the coilover to the axle, and then the three bolts in the engine bay, and bam out it comes :) but I can understand the hesitation, definitely. Shit if you weren't in the Shire I'd come take a look; a bit far to go after work and I get busy on the weekends going down to the gong heh
https://www.sau.com.au/forums/topic/400642-new-to-sau/#findComment-6365139
Ah true - I thought so.
So it's not possible to take the wheel off and adjust from there?
I have a few mates who are mechanics, but I don't wanna go to low and screw my handling!
Also after a R32 Gtr front grill - colour doesn't matter, I can paint it. Looked through parts for sale only found one, PM'd him but no reply.
Edited by ls128
https://www.sau.com.au/forums/topic/400642-new-to-sau/#findComment-6365225
Hmm, trying to remember if it can be done, probably? Someone else could probably give a 100% answer on that. But I think it should be able to be done :) As long as you get the spanners to undo the locking rings, it's worth a shot, just make sure you measure how much further you move it so that you can do it to the other side the same.
https://www.sau.com.au/forums/topic/400642-new-to-sau/#findComment-6365441
Alright thanks mate.
Yeah, looking on ebay for a C spanner...I haven't been able to find one locally (not that I have put heaps of effort into looking)
I haven't actually properly looked at the coilovers yet, do they usually have the model visible with the wheel on? Or is it a matter of removing the wheels and getting right into the wheel well to know what model of HKS coilovers they are..
Yeah, I really just want to see how low down it does go haha
https://www.sau.com.au/forums/topic/400642-new-to-sau/#findComment-6365808
  • 1 year later...
some coilovers are easily identifiable by sight (Ohlins, Bilsteins etc) but for most Jap coils, they have a model and then variations: Cusco Zero 1,2, 2e, 2r etc etc.
Best if you get us pics of your coilovers, but to do that you'd need to take the wheel off to get a decent pic anyway, so you might just find the model on!
also - Owen, are you serious that's all it takes to remove a damper?!?!?
https://www.sau.com.au/forums/topic/400642-new-to-sau/#findComment-6878672
Remember if you go low the car becomes a defect magnet and it will also handle worse!
If you change height in any way make sure you get an alignment!
https://www.sau.com.au/forums/topic/400642-new-to-sau/#findComment-6878675
Oh how much i've learnt since this post last year!
Worked out they are HKS Hyper-D.
The thread on the coilovers is rusted so cant be lowered without taking the coilover out of the car, which is well effort :)
I've put up a build thread in the projects section!!
https://www.sau.com.au/forums/topic/400642-new-to-sau/#findComment-6879746
Good work :yes: I love a good build thread :woot:
https://www.sau.com.au/forums/topic/400642-new-to-sau/#findComment-6879786
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
