Hi All,
Selling my S13 Silvia, List below:
RB20DET, 5spd Manual
Rb25 Turbo
Front mount Intercooler
Bigger Fuel Pump
Straight through exhaust
Pod filter
Z32 AF meter (i think)
HKS EVC-S Boost controller
HKS turbo timber
Boost,oil pressure,oil temp and water temp gauges
Nismo gear knob
Coilovers
P1s
Has hubcentric 25mm spacers all round
Shimmed diff
lock spacers
new tie rod ends.
rear strut brace
Brick headlights
Crystal (i think) corners and tail lights
Custom front bar (Sort of like Rocket bunny one)
NIsmo?? i think Side skirts
R34 (N/A) Front Brakes
Car has working aircon, but would be perfect if it was re-gassed
Sunroof
Tuned by Terry when he was at HPR. Car currently makes 210 hp reliable on 12.5 pound (which is the amount of power i was after)
Car looks Very clean and looks great rolling around the streets.
I have let the car run out of rego (Not registered and does not come with a RWC) as i was planning to use it for the track only. Reason i am selling it is because i am picking up another car which i got off one of my mates who lost interest. Realistically i love this s13 but new car is more set up for the track.
I have taken my good seats out of it and put clean/comfortable cefiro seats on cefiro rails in S13. 3 seat bolts line up but another part of the rail will have to be modified for them all to be bolted (i can do this but i thought i would leave it incase someone has replacement seats and wants to sell cefiro seats).
only things that have changed since i got it rego'd is; there is no longer any back seats and it is not mod plated for 2 seats (i will source some if buyer wishes)
didn't have straight pipe when i rego'd it.
Interior is fairly clean, Dash has cracks but over all it is clean. (door cards etc have been painted black and some of it has come off) they also have leather/Vinyl trim in the inserts.
Rear tires scrub as your driving along a little (i personally love this). i took my mate for a drive in it (he weighs 100-110 Kg) and passenger back tire scrubbed a lot with the 2 of us in it, would be perfect if they were rolled a touch more.
Price: $6900 ono
PM if you have any questions
https://www.sau.com.au/forums/topic/400703-s13-siliva-p1s-rb20/
i think its been about 8 or 9 months, i have been playing around with the car in the garage slowly over that period as i have been dealing with back problems over that period so it has been given the attention i would have like to have given it.
forgot to mention has never been defected either, only ran out of rego as plans were to track it.
thanks for the comment, glad you like it...
Nice car, do like.
Skirts look like AD MoonCraft Evolution, I used to have a pair, pics below.
Just thought I'd add that :).
Thanks for posting mate.
Ive always loved the shape of the side skirts.
Love the blue on your s13...
  • 1 month later...
  • 3 weeks later...
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
