as title states
im looking at getting 18x10 +24offset. with R disk and O disk for rear (more dish) but heard i must get r disk for both? frown.png anyone know about this?
want it to sit flush and agressive but with no rubbing. (dnt want stupid camber spec either) Just inside the guard would be ideal for lowering purposes.
what are others running? pictures? did you need to do any modifications to fit?
thanks.
Edited by JesseJ
https://www.sau.com.au/forums/topic/400841-best-widthoffset-combo-for-32-gtr/
i think a R32 GTR could take a bit more offset then +24 i run +20 on my GTST and its flush and my mate also runs +18 on a 18x10 all round on a GTST, so i think you could sink in some +20 to +15's in there nicley and depending on how aggressive the look your going for is +12 i have seen looks mint ;)
dude use the search function there is sooooooooooooooooooooooooo many threads. like the R32 pics thread half have rims pics and rim sizes and offsets.
32 Gtr - 18x10+12 is do-able.
look at my content, posted a few of my car with rota grid R with the above offset. looks wickid tough agressive and then some.
only issue is my car was lowered a bit, had front rubbing on passenger guard. annoyed the crap out of me.
personally for sake of $$$ in wheels and tyres im looking at 17x9.5 +15,20 wheels next time. and spaced accordingly maybe 10/15mm bolt ons.
end of the day its your car.
Hope this helps!
Yeah with appropriate height on car i.e. not dumped on its ass.
You can do 18x10 +12 no dramas without rolling lips.
If you want a dropped car with camber etc you can do bolt on spacers, and then lip guards etc to suit.
thats running 265/35/18s btw with a tiny bit of stretch, could run 275's i think then on a stock gtr you start running in to problems.
for a road going car i wouldnt go any bigger personally. looks tuff, rides well enough not absolutely rough as guts and will def fill those pumpd guards!!
get em.
running 18x10+18 with 275 tires all round
issues = tires rubbing on rear gaurd so we rolled it problem gone,
also passenger side inner plastic gaurds rubs a bit on full lock.....doesnt really bother me though
Thats the thing, i want it faily low :)
18x10 + 18 seems to be a good combo (going from another forum) or maybe play it safe and go slighter higher so i can lower it how i want..hmmm
good to know rolling the guards = no rubbing issues (Was it rubbing on inner or outer or both?) - could you tyre tuck if you wanted to?? any piccies?
Edited by JesseJ
front wheel just rubbed on inner gaurd only, rear rubbed on outter. To tuck the tires in on a 18x10 i see guys running 265 tires which tend to just fit under gaurds without needing to roll them
hers some pics of how it sits
  • 2 months later...
Old post but saves me starting a new one....when people say "roll the guards" does that mean the front aswell?
I got work xd9 in 18x10 + 18 with 265 KU36 rubber all around, scrubs a tiny bit at the height I've got it at (pretty low) so will prob get my rears rolled, what can be done for the fronts??
Remove upper guard liner and give them a roll too?
Set of Work VS-XX I've been working on. 18x10.5 et 23ish. Filled, drilled, and shaved mounting pads 8mm. R-disk front, O-disk rear. Natural weight camber curve will pull the wheel inside the wheel well as it is unloaded in the photo. Front looks the same. 4.5 inch lip on the rear, 3.5 on the front.
Car sitting on a set of Enkei RP01's. 17x9 et20 on Hancook Rs-3's. My gymkana set up.
Edited by warp speed
When u say shaving the mounting pads, do you mean the mounting surface on the back of the wheel?
I raised my car about 8mm all around today all seems fine now, not too keen on rolling my rear guards
Correct.
I've been told ideal/largest size for 32 GTR is 18x10' +20ish offset
Depends how low your car is as well :D
i just got work xd9's in 18x10 +18 with 265 KU36 tyres (which have no stretch on the rim)
definetly no way of tucking them in the guard, but if you roll the guards you can wind the coilovers down another 10-15mm and it wouldnt scrub
mine have about a 2 finger gap between wheels and guards....
Ah ok, well I have 18x 10.0 at around 15-20ish off set ( can't remember) though I do have my guards rolled..That's with 265/35 federals
If I wasn't interstate I'd walk outside and see if the fronts were rolled for you :)
Edited by GTR_JOEY
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
