Hi from new member
doxximus Skyliner
I sense there is a lot of hate in you my son, you must not give into the dark side, remain focussed and be happy.
Perhaps sing a little song.....
Would you like to swing on a star
Carry moon beams up in a jar
Would you be better off as you are
or would you rather be a fish
A fish is an animal that swims in a brook
He can't write his name or read a book
But h............ooops, um....tooo late
Nat, all you have to do (if the pic is are already up on the web like those ones of your car were) is click the Img button...copy & paste the link to the pic...then click the Img button again. Done!
p.s. I'm blonde too, trust me it's foolproof!!! hehe
