Hey guys,
If anyone has got a 32 gtr with either of the Enkei RFP01, Gt-c's or Varrstoen 2.2.1 ? TE37 copy in 17x9.5 and Gtr offset could you post some pics of the fit, stance wise, profile and from either behind/front of how they sit within guards and on what tyres also.
This is purely for a reference point.
I had Rota Grid R's before in 18 x 10 + 12 and am thinking 17's for the next gtr and want to see some examples.
Obviously i have searched google images, other forums, this forum, all the R32 Gtr 'what wheels do you have??' forums on GTRoc as well and have pooled a healthy ammount of pictures.
Just after more in these styles.
Thanks guys!!
Anyone got any pics?? come on has to be some pics.
Im especially keen on the matt black Enkei's, not sure which is the one that has the lil bit of dish????
matt black with the red enkei symbol if possible!! pleaseeeeeeeeeeeeeeeeeeeeeeee
haha... noooooo wayyyyyyyyy man!!
too expensive on tires, looks bad IMHO, ride would be shocking and like my guard liners, guards etc as is.
prefer appropriately lowered, good offset, and no bigger than 18's but would prefer 17's for ride, tyres etc.
17" / 18" look best on a R32 GTR.
17 x 9 +22:
Looks nice but for more of an aggressive look, you'd go at least 17 x 9.5 + 18 or so...
I'd say 18 x 10 +18 fits very good:
18 x 9.5 +12:
Besides the 1st pic, I know the rest of the pics are not TE37 / RFP1's, it's to give you an idea of fitment.
So I'd say you would go 17 x 9.5 with an offset between +18 to +12.
Thanks man!! i have just about all of these pics lol!! massively have gone through google for R32 Gtr pics etc.
Im basically going for the following look for the next gtr.
wingless boot, N1 spats and rear OEM spats, front abflug lip, n1 intercooler ducts and East bear aero mirrors.
Want some 17's im thinking for tyres etc in an agressive fittment, or 18';s if the car comes with maybe untill i wear tyres out.
Love the TE37 look and would consider varrstoens in 17x9.5 + 18 maybe with a spacer to make it that much better. or the enkeis (love the matt black).
I do love the XD9's as wel, but i reckon they look good only when slammed and hanging out of guards. or front front/back side on not 100% sold.
Close enough look to my R32 GTR :)
The R32 GTR with the white TE37's in my post, is my car.
Yeah stick to the TE37 / Varrstoens and if you ran with spacers, you'd only want to do the rears, yeah..?
They should fill the fronts quiet well.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
