As some of you are awared, I've been lurking on this forum because I love the skylines......and you guys too :headspin: I hope you guys don't mind :)
I don't have a skyline and love to get a GTR down the track. I actually own a s2000. :wassup: The S2000 parts are pissy weak compare to your skylines. My engine is being rebuilt atm. My next weakest link will be the differential. The S2000 has a torsen diff and an aluminium casing. Most s2k with a little bit extra power tend to crack the diff housing clean.
I've been thinking about mechanical diff, silvia cusco/kaaz diff or a skyline diff.
All of the diffs will need custom fitting for the s2k as there is none strenthened s2k diff available in Japan.
What would you guys recommend for a strong, lighweight and inexpensive complete differential?
dont think the mech diff is lighter? not sure, they are both not very light items.
New mech diff is around the 2K mark, second hand, depends on if you get lucky or not, but reasonable price is between 800-1.2k for good condition from what I have seen.
Not sure what a stock diff is worth - make me an offer:)
sorry for another amateur questions ;)
could someone kindly explain the differences in the differential betweent a gtr vs gts and r32 vs r33? (I don't think it will be economical for a r34 diff :P)
how easy is it to blow a diff for you guys eg what kind of power output will blow a for example gts diff?
gts diff wont blow, but it will open wheel as its a viscous type.
A mech diff is not viscous, it is Mechanical inside so basically is alot stronger. for ur type of driving, a 1.5way mech diff is what u want. This is made for circuit racing aswell as daily driving etc.
Check out the s2k forum as they would know alot more then us about puttin a better diff into ur car aswell as what types are available.
Cya Dan
http://www.cusco.co.jp/english/e_cont.html
everything you ever wanted to know about mechanical diffs. If you want to get into a bit of dorifto, go the two way. If you dont want to get into a bit of dorifto, go the two way:)
If you can source a 1.5 way that is fine too I suppose, I have a two way - very predictable, and if you get sideways and back off too quickly, you dont have to worry about the rear end swinging to the other side of the road, it just gently pulls back in.
Just be warned, they can go clunk alot, and make alot of noise in service stations and car parks when the wheels lock and you are turning corners at slow speeds.
thanks for the links dan
I've been a member of that forum for the past 2+ years
I would say that I knew most things about the s2k diff and it's aftermarkets. It's the first weakest link in our drivetrain you know. It did not take long for "Phoenix" to break 2 diffs with his stock/near stock power :throwup:
Sad to report that the strongest way of strengthening the s2k diff thus far is a set of kaaz/cusco lsd, J's 4.44 crown+ pinion (which I have), comptech reinforced diff housing and drop most of these stuffs in a cryogenic tub. Unfortunately some owners have reported failure with only mod power output (300hp). I am afraid that this combination won't be any good for me.....prob around 300rwk if it ever finish :P
Thanks for the links and excellent points steve......I think I will go with a 1.5 way for hill/track run rather than drifting.
busky2k, the only place that does it is in sydney. It's too heavy to send most of the diff up there and it prob won't last any way.
Thanks for all the informative responses guys :(
So is there any difference between the gtr and gts rear diff?
Is there any difference in r32 vs r33 rear diff?
R33GTSt - 4.11:1, R32GTSt - 4.3#:1
not sure about the GTR, as it had a larger engine.
If I had to choose, I would say go the R32 GTS diff, its shorter = more torque:)
BTW, D1 garage had (think they still have it) a TRD diff centre, dont know if its any good to you.
I think ur lookin at trouble puttin a differnt diff into ur s2k homie. to much customizing.
if I don't look for something new I will have to be very gentle with my car
It's no fun having enough power to embarass some V8 and do rolling start with every drag :)
Given that most of you guys claim to go through Maccas in under 10sec on the other thread :wassup: I figure that I will need to adopt some skylines parts to hang around with the best :)
Is there much difference between the viscous oem diff and the 1.5 mechanical diff in term of driving dan?
    • Haha thanks everyone, I'll take everyone's suggestions into consideration. If I do eventually choose a car ill post it here update on the mods I do.
    • I found the ingredients at larger amounts from a Coffee Shop. 1kg Citric Acid for €8.50 500g Baking Soda for €2.50 I tried it out tonight distilled water (I got from my ACs) and dish soap. It does get bubbly with dish soap. In just two hours the hanger has improved significantly and rubbing against any remaining rust seems to flake it off. I'm going to leave it a little bit longer and see how it goes. I have read that someone even used this solution in an ultrasonic cleaner to clean a seized water pump which brought it back to life.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
