hey guys, just some parts for sale of my R33 gtst s2.. wanna get rid of it all.
drivers door trim $30
dash $50
passenger guard $30
x4 r33 gsts wheels $100
rear window surround plastic $30 for both
battery surround $20
climate control unit $20
foot pillars $25 for both
cluster surround $10
wheel surround $10
cluster (rpm gauge is playing up) $30
door pillars $20 for both
standard side mount cooler $25
rear bar $40
drivers mirror $20
rear door trims $40 for both
boot with s2 spoiler $70
under steering wheel plastic $20
passenger door $40 with glass
boot grill $20
drift poddy $10
rear view mirror $10
roof lights $10
roof center light $10
sun visors $10 for both
pertrol cap and door $10
tail lights $50
center consol $20
glove box $20
rear seats $50
car tv tuner and after market ariel $15
bonnet stand stick $10
lsd diff $80
abs unit $30
front and rear standard sway bars $30 for both
Post will be added on to price, cheers guys, im located in hallam, victoria.. contact me on 0433 467 819.
https://www.sau.com.au/forums/topic/401696-cheap-cheap-r33-gtst-s2-bits/
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
