Use the newspaper method of creating the clearance required.
Shamelessly stolen from the 300 forum. I used this to get my rears to fit and it works a treat!
First of all, you're going to want to jack up the rear by the tow hook, and remove he rear wheel. The you're going to want to disconnect the lower mount of the rear shock.
Remove the nut and bolt, and swing the lower mount out of the way.
Make sure the lower mount is clear of everything. You do not want it to catch on anything.
With the car in the air, and the wheel at full droop, this is what it looks like:
Not too bad, but remember it will camber in a bit, like so:
The fender just catches the tire, so rubbing will occur.
Next, you're going to want to heat up the fender, from where I'm point at, and to the right. Use either a heat gun, or if you're brave, a propane torch, lol
You want to hit the fender from the bottom and up, to heat up the lip of the fender on both sides.
Next, grab about less than a thumb's width of newspaper for the initial treatment.
Again, I'm using mechanic's paper floor mats. It works just as well.
With the fender heated, stuff the newspaper into the wheel arch, between the fender and tire. Make sure to have the newspaper span the whole area you heated up, or else you'll pull one section more than the other.
Then you're going to drop the car slowly, until the tire touches the floor, and the wheel begins to tuck itself inside the fender.
Now, it will make some noise it is just the sound of the fender sliding over the newspaper. Let it sit for couple of minutes, to give the fender time to cool off and take shape. You're going to want to then raise the car and remove the paper. Drop it back down to where you're tucking tire, like so:
You're going to want to check for rubbing issues. What I do is take some thin paper, and slide it between the tire and fender:
If the paper snags, then you still need to pull more. The tire was touching the fender in the area between where the paper is placers in the two pics.
Again, heat up the fender, and grab more paper.
Rinse and repeat as needed.
You can see the fender slowly taking a flat flared look
Just as a warning, the driver side fender will require more effort to pull, due to the gas cap there reinforcing the fender. So don't freak out if you need significantly more newspaper on the driver side than on the passenger side.
Keep repeating the process by adding a slight amount more newspaper at every pass. My passenger side took 2 passes. Driver side took 4. Again, this is normal. And here are the results:
Hope this helps everyone.
Michael - thanks for the writeup mate. Unfortunately, I don't have the b*lls to do it myself but I am sure alot of people will use it. The clearance you have at the rears is crazy lol.
I took off the wheels off yesterday and it seems like I have done some substantial damage to the lip on the guards :mad: .
This is a pic of the rear guards...
Picture of the front guards...
It may be the case that I need to flare the rears out abit (due to the extent of the rubbing compared to the fronts).
I have also removed the front inner plasticguard as per the recommendations but the wires (for the headlights) are exposed to potential water and dirt. Is it safe to have the inner plastic guard removed? I don't want to encounter the problems of my car shortcircuting lol. I can see why removing it would partially stop the rubbing though.
PhillB to the rescue tomorrow. I'll definintely get some good before and after photos for everyone =). I just hope the the pre-existing damage on the rear guard lip won't be a problem.
Edited by newbatplay
So Phill from <http://www.phillbenterprises.com/guard-rolling-service/> came to work on the guards on Saturday morning and I'm glad to say that my dream wheels finally fit with NO SCRUBBING OR SCRAPING WHATSOEVER! ! :woot:
All that was required was a good flat roll on all corners. The front inner guard plastic was shifted abit higher and locked into place by the lipped guards (refer to photos). I have also spent today re-patching the damaged inner guards with some primer and touch-up paint.
We realised that the previous owner tried to do a DIY job rolling the rear guards (possibly with a pole) which caused the damage. The front guards were not previously rolled.
Thanks Phill.
As promised, here are the photos...
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
