Yeah this is true
Okay I'm putting a shout out to anyone that knows of or has an old piece of shit Ford Laser from the 80's to early 90's that they either want to get rid of. Doesn't need to be regoed or going really only want it for the gearbox driveshafts and front hubs for a project
If anyone knows of one around could they let me know please
Thanks
Id think these would be a dime/dozen at the wreckers...but if you can get em for free, all the better.
Nice pup Jarad
Nice pup Jarad
The cars might be a dime a dozen but wreckers still seem to want top dollar
Not in a hurry just yet but if I can't get one cheap will have to go the wreckers option
Nice block
Think it would look better in my car
You can have mine, it's got pretty pistons and all fitted :)
Good on ya martin! i think the hardest part is when you go out for drinks.
Are trying patches or anything? or just beating the the sphincter of the universe cold.
Not much been happening, just arrived back to newe from work this morning and caught up some sleep from the past two weeks.
Nah no patches
Just cold the sphincter of the universe and trying to avoid the usual things that I would do when smoking
I learnt about the lack of sleep and accumulated sleep debt at a teeing course with work the trainer bloke threatened to tip me out of the chair cause I was snoring
Had been early starts and late finishes all week up to that point
Stupid auto correct
I wrote cold the sphincter of the universe I'm sure
And a training course nit teeing
How the f**k does cold. the sphincter of the universe. Auto correct to the sphincter of the universe?
C O L D. T U R K E Y
Edited by m.j.h
Im quitting to martin good work, been since saturday without one, but im trying the hard gum to help, makes it a fair bit easier imo
So these drinks still happening on friday? gotta leave early to get there lol
Forgot about drinks on friday, been flat out.
will be still good to come for a beer or two, unfortunately wont be out all night as i have too much stuff on this weekend.
see you guys there.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
