No idea sorry, they sit alright in the Gtr guards though. What rim is it?
I have a spare set of hks cam gears that I'll sell for a special newe price if anyone is interested.
Could be interested in the cam gears mate, it's the next bit on my list. Can you pm me some details please and can go from there?
Or could have a chat about it tonight if your going to the pub?
yeah chat tonight. There at Pauls place atm, but if his home this arvo i'll try and grab and take some photos. There both in excellent condition, except the anodising is fading slightly on the EX cam.
I picked up set of cheap tomei ones, so i'm going with them just to keep the tomei theme going on my head (poncams, retainers, springs etc).
So keen for tonight, work has been the worst and i only started an hour ago, f**k accounts payable, coordinators, and useless team members
this forum needs a like button
Sounds like some Lulz where had after I left
Good night good food and good company,will have to make sure the wife comes along next tiime
EDIT. Thread is up in the events section
Feel free to add/edit it as I can only use my phone at the moment
No Internet makes M.J.H something something
Edited by m.j.h
Wrong thread but maybe?
But nothing happening in here lately so might as well post the spotted cars as well
it was getting quiet in here thought people were dropping off their perches :P
Its the 3rd time in 2weeks ive seen the car, perhaps a stalker :P jks
Me and ant dog are at the snow having a lovely time till sat
Jelly!!!!!!!! :mellow: Have a good time guys!!!!!!!!!
Ill be back whoring up SAU in a couple of weeks, work is consuming me lately............................. :down:
last i saw of my GTR was on a tow truck on the way to Team K Kustoms for a full rebuild.....
This is whats going in her :D should be done by the end of this month then ill come up from the coast for a few meets
CP Pistons
Manly Turbo tough rods 1000hp
Tomei Head gasket
Tomei Baffle pan
Mines Cam baffle
Tomei Oil restrictor
ACL bearings
studs
Tomei valve springs
Gates racing timeing belt kit
Gasket kit
Stock/N1 oil pump
Reimax gears for oil pump
CP Pistons
Tomei Head gasket
Tomei Baffle pan
Mines Cam baffle
ACL bearings
studs
Tomei valve springs
Gasket kit
Stock/N1 oil pump
Not a bad little setup - plenty of supporting mods for when the power bug hits :-)
Edited by wedge_r34gtr
CP Pistons
Tomei Head gasket
Tomei Baffle pan
Mines Cam baffle
ACL bearings
studs
Tomei valve springs
Gasket kit
Stock/N1 oil pump
Sounds like a nice list of parts
What turbo/s you going to run?
Come along on the 26th anyway doesn't matter what car we will only be doing the speed limit anyway
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
