they be fine, got 12 rims at home with tyres so im not lacking rubber atm :P
probably wont have them done for sunday which sucks, rather not be forking out for another wheel alignment when im gunna have to do it again when coilovers come
Hmmm not sure, if i dont have the gearbox out that will be priority i think........... Depends how i go tomorrow night with moving cars around. I need to tow the rodeo out and put it in the right bay, take mine from the left bay and put it in the center bay (so i have 2 car spaces to pull stuff apart) and then we can service yours in the left bay.......... Freakin musical sheds!
Sorry Martin, dobbed you in........ Hope you dont mind............
http://www.skylinesaustralia.com/forums/topic/407632-tommy-kaira-25r/page__fromsearch__1
PS - If you do mind, COME AT ME BRO
Fffffffffffuuuuuuuuuuuuuuuuuuuu
Nah it's all good man
Replied to thread
Haha well i thought if anyone was going to be a guru it was going to be you............
Dunno bout being a guru
Someone asked me at the Charlestown meet
Them. Is it a real Tommy
Me. I suppose so how do you tell
Them. It will have a build plate on it somewhere
Me. Shrugs shoulders
Even if mine is a fake I still love it and wouldn't change except maybe for an R35
mat gunna do oil,filter,coolant tonight
makes it less hassle for you :)
got no problem doing them, never done my belts but guess ill learn haha
just dont over tighten right?
also probably wont get to do spark plugs dont have a socket long enough :(
Have you bled cooling systems before etc? If not, dont touch :)
Oil and filter is easy enough, just make sure the old filter seal comes off.
Belts are easy, and yeah do NOT overtighten them.... Make sure they have some deflection, if they are not freyed or too worn you can leave them for later too (up to you)....
Will make life easier in the shed of broken cars at the moment lolz :P
Exactly. i like martin's version.
Yep!
Subtle
Sexy
Smooth
And he has a nice car.................................. Wait.................................... Wha
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
