Nah no trolley rides this time
Maybe next time
Although Melisa is talking about having her works Xmas party at home and the driveway is long enough and steep enough and the supermarket is not far away.
Your a crazy kid!
NTY benji :P ill get a bad image
nah man i dont, spaghetti!!!!
LOL...
Dude.. think about it, your car enthusiast rating would instantly raise up a level to Otaku.
but in all seriousness, don't know if I'll even be able to go, not sure if my car will be ready.
The mechanic is really busy atm and not sure when he will have time to work on my car. =\.
