haha yeah but you can buy 2000 model gtts, s15s, subarus for 12k at starting price, evo 7 starting price is over 20k.
they saw that if they made it 4 door and made it more daily theyd make a f**k load of money, hence the rarity of them and the common ness of other rexies haha
man ive had many beers, i got the dog on my lap under a blanket together watching better homes and gardens, doesnt get better for a friday night man
Emma is a cover huh? You are so fkn gay! Lol
Look at this S15, shes asking $16k and its clearly been in a front ender. Look at the horrible alignment of the bonnet and drivers side headlight.
" Owned since new, Its in perfect original condition, its just had some paint chip touch up work done to ensure you get a car that looks as good as it drives."
Yeah right...
And the ad
http://www.carsales....82+903&find=s15 200sx spec s |CarAll&silo=Stock&num=15&sort=default
Dude my bonnet etc is aligned crap because I've hard it apart a few times and too lazy too put it together properly... So your not always gunna be right....
PS - Skyline forum, not many care about Silvia's (Benji) or rexys (Zali-Rad)
Lolz
Lolz
Yeah, but if you look at that one, the bonnet is lined up perfectly on the left, but actually overlaps the headlight on the right.
Meaning the car has probably been hit on the right and it hasnt pulled out properly. So the body is what is causing the bonnet to be out of alignment.
Speaking of train wrecks, theres a blue S15 on carsales at the moment for 16k that was in a rear end accident where the boot was in line with the rear window (glass shattered etc). Hate to think how many kg's of bog that thing is carrying. No one has bought it yet thank god
EDIT: just read the "this is a skylines forum" part hahaha.
haha how is that gay? what are you doing cool-mo-D?
i like learning about all the renos and gardening
yeah that doesnt mean anything benji haha. you know normal "enthusiasts" actually work on their cars :P if i was doing alot of work on my car id probably take the bonnet off too.
Lolz
so if you dont have a skyline your out of the club??
you havent been to many events with the club have you :P
Fark all.... Watching some shit on TV with the dogs lol (wondering if Chookie has killed himself via coilover yet)....
My bonnets been on 4 or 5 times now, guards, lights and bar too, no damage anywhere
Your 34 looks straight as.
Gaz's S15 has been hit hard twice in 2 seperate accidents BOTH while he was stationary and the car was repaired 100% with pics from start to finish and full Respray... $13k worth of work, soooo what's the problem? I DARE you to bring up the subject of how his nostalgia vehicle is worth nothing lol...... Oh that would bring Lulz :laugh:
Nah, thats okay because a vehicle will be fine when repairs have been done properly haha.
When you cant see your reflection in a rear quarter panel, you know something hasnt been fixed correctly.
I've inspected some S15's with absolutely cringeworthy repairs done to them.
hahaha yeah but if it doesnt have over 300kw and 250+ wide tyres youll hate it so you dont really get a say :P
Dude I missed this post!!
I give you an A+
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
