hey so apparently its my turn to organise a cruise!!!!
throw up ideas!! id like to do maybe west? north would be to hard to coast boys im assuming.
ill do some research as to where to go, while still basing it around an xmas theme hahaha.
if you got ideas let me know! only lived up here for 9 months and have rarely left newy so im fresh.
even for the drive bys?
because it don't look it..
It's an 80 zone... Was doing 40 across the bridge...
But I do get what your saying.... Happy to set it to private BUT my phone won't let me
think it was a 90 zone and everyone was in second gear?
dunno, im sure theres been worse videos posted on here haha. video the maq pass cruise for example, or putty road which all the execs attend. this was nothing compared those cruises, everyone was very well behaved
I've got a few but might need to spend a day driving to check them out
I'm a granny,this cruise was all above board,is any one saying diff,
I saw no stupid shit happening,was a top day.Every one enjoyed cruising.
Just spoke to Norm, he is keen to come along.... He wants to go to Scone I think he said
Remember the HWP saw all of us driving sensible :)
scone is a treck! hahaha
i looked at the road from cessnock to wollombi and then to broke and back to cessnock? might be to spaced out
A lot of the roads are shit mate, do you wanna just go play out on the back roads out here?
yeah i tghought thatd be the case.
yeah possibly? im not to sure haha. its hard when youve never been there.
Well how about I take u for a run through the back roads? We need the Cos Racecar Evo to run so what better than an impromptu mini cruise?
putty road sounds good to me but im up for watever,dunno about the xmas theme thou wats the go with that jarrad lol
There is snow.... Snow is white.... Tyre smoke is white.... So I guess if you look into it, basically Jarrad is a hoon and just wants skids!
(please read the PDS as everything I think or say may be full of shit)
u do have a point mat maybe the snow themes not so much of a bad idea.....track day :whistling:
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
