well my GTR may have a boost issue, took it for a drive at lunch and it didnt seem to hit boost properly, i finish work at 4:30 so ill drive her home and im just hoping it was just not being able to open it up enough, display was saying it was boosting but it didnt feel like it was pulling like it should.
Well if you think there is a problem lay off the boost until its checked.... Mine felt similar when the injectors started to block and it started leaning out, you could have any number of issues or nothing at all BUT dont test it the hard way!
yeh im over it, if something is f**ked good chance it will go on carsales.
I dont have the time or the money to keep funneling cash into it atm and its my primary mode of transport for work. im hoping its nothing may just me being paranoid ill find out when i drive home, ill give it a little bit of a stab see if it boosts at all if not ill just baby it home, its going to the mechanics tomorrow for run in service anyway.
Edited by T4NK
Dude its a modified car, shit is gunna go wrong and you said you were out thrashing last night...... Look at the run of luck i had!
Teething problems are going to happen man, you could just have a dodgy vacuum line, blown cooler piper (or leaking) or a million other things BUT all fixable!
Dead cat?
So what your saying gummy is that when I most started slipping I shouldnt of kept "testing" it's durability for the next month? Lol
:blink:
You on the rums already?
Maybe Matt should have listened to his own advice...His clutch welding abaility wouldn't have been near as good.
Adam, know exactly how you feel. Stay with it mate...it will be all worth it in the end
Clutch welding specialist right here........
Yeh if its something simple then all sweet, but if its a rooted turbo or something thats a pain in the ass..... i wasnt thrashing it down old pac didnt take it over 5k rpm sinec run in service has not been done yet, was a slow run.
yeh, well after 10.5k on engine, service and radiator, im over having issues lol so is my wallet.
I still have a stock engine and i think i have spent 25-30k lol
And THEN you will find something else to break, everytime you make something stronger you introduce a weaker link somewhere........ It part of the fun man!
    • A quick google, and some E39 users have found pulling my sensor out/apart and cleaning it alleviates their issue. Then get the oil warning to go off, and once it is off (from the sensor saying it was unhappy) some find they can just unplug it and it is happy to just keep going now. Maybe give it a crack? If you can actually pull the sensor apart, hit it with some electrical contact cleaner.
    • Yep. In the E39 it's slightly different than the others. Honestly I'd just leave it but every time I drive the car it tells me oil is low and that just makes me check the dipstick. It is a BMW Afterall and it tries to expel it's own oil regularly.  Thankfully it's not like my E90 that has no dipstick at all so you just gotta trust it.
    • Was that also a typo? $350?! Just typing "BMW oil level sensor" and prices start out a lot more sanely than $350. I'm guessing it's a sensor used in one low volume model only or something?
    • They kept the product number the same, so we "didn't pick it up when packing your order". If you packed the order, you clearly saw the box wasn't Hella...
    • Actually, the equivalent skyline part is both cheaper and simpler, maybe you should come back from the dark side?
