Sneak peak at my engine bay - will still need some work in Perth, but getting there:
Catch can looks fanatastic. Wish i had the plenum painted black now too.
Edited by wedge_r34gtr
haha good stuff on the kms!!
ah thats no good martin!! im about the same, working tomorrow morning before our drive so i dont mind a quiet one :)
if anyone wants to sus out some roads me and martin are gunna go for a cruise tomorrow.
Yeh well as long as i have boost ill be going, im not to sure whats the deal with it, gave my boss a lift he said it was rly fast and i was just like meh boost does not seem to be working, i can hear the turbos spool and it has some boost but does not fell like maximum boost, maybe its just me imagining things and im used to it so it needs more boost now, meh fark it for tonight will get it sorted tomorrow when the new rad goes in ill let u guys know lol.
yeah man could be a number of things but i wouldnt think its serious, if your boost gauge is still working it could be something with the boost controller.
just ask your mechanic if he changed anything, because a lot of solenoids have to be pointing in a certain way
Ah Righto, no good for a cruise?? Well scope it out and see I guess.
The road to broke looks like a 1 lane situation too. I suppose sat Arvo will be one o the busiest times so today will be a good test.
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
