can anyone with a 34 GTR please confirm for me if the following plug should be plugged into anything, my mechanic seems to think the 02 sensors are fine, he thinks the cause is the oil in the intake pipe getting on the AFM causing it to not read properly and to fix this i need to change the turbos out............... im not to sure what to make of that tbh
Is the car missing or is it just a boost problem?
if its AFM it should be running like shit and missing here and there i would have thought?
if its just not boosting sounds like a leak someone? maybe in the inlet manifold or something if its still registering boost?...
im not mechanic, just thoughts..
also if alot of oil is around the AFM.. could mean new turbos.. leak on the inside somewhere?...
If your talking about the plug near the twin turbo pipes yes it should be plugged in. Its either one of your AFM plugs or o2 sensors plugs.
If one of Your AFMS isn't plugged in, then this would explain your preiodic boost.
A little bit of oil residue in your pipes is normal - any running/pooling oil isn't and is a sign your turbos seals are shagged.
AFM's do funny things - particualry if there on the way out (i.e. speratic voltage reading). Down low they aren't really doing much, up high on the other hand....
Edited by wedge_r34gtr
Mine did a funny thing............................................................................................................................................. It went in the bin and i laughed! :laugh:
yea my car runs much better without them too.. but i did still leave them attached to the engine!
LMFAO THIS GUY BAHAHAHAH
Yeh i was like dafuq is this plug for?????? the oil is all the way to the airbox, my mechanic changed the plugs cleaned the AFM and it boosted and ripped then like 40km later it stopped boosting again, it misses as it hits boost and boost does not come on but the MFD is reading boost to .9 bar :woot: so its all spooling and shiz. i have 2 plugs that are taped togeather behind the twin turbo pipe and 1 is plugged in and 1 is not.
Well mine is suposed to be a farking specialist who has worked on these many times....... Team K Kustoms did the work the motor runs realy well the build is great on it even without it boosting properly it still has shit loads of power, im waiting on a call back from him atm, my main issue is the 20L of fuel it used to do 75km on the way to work.....
i might try unplugging the AFM and see if it runs without them and comes on boost, after he cleaned them and changed the plugs yesterday it went like a rocket, he thinks the turbos may be spitting oil back up the intake pipes and coating them in shit so they are not reading correctly.
Edited by T4NK
yea see what your guy says...
i cant imagine it would run too well unplugging the AFMs...
Does it have an aftermaket ecu? was it tunned after the build? sounds like it is running very rich....
stock ecu, not sure how much u can tune a stock ecu.... well if it will come on boost with the AFM off then i know thats the issue and i just have to work out why all this oil is in the pipes
yea cant tune stock 34r ecus.. mine had a custom chip installed onit that was very rare that could be tuned, but there arent really any people who tune it anymore so its pretty useless.. ive got a haltech running via MAP now.. much better!
yea a large amount of oil sounds bad.. maybe check pipes on the other side to see if there is more up near the inlet etc?..
The soldering joins on my Afm f**ked up when I cleaned it. Can't remember what happened though... Not it either wouldn't start or revs were bouncing all over I can't remember. But as Joel said it could do funny things when on boost because more air more volts and boom.
I would only be touching what your mechanic says dude. If you f**k something it's bye bye warranty.
ATM it's his job to fix it not yours
Yeh he told me to give the pipes a clean and the AFM to with the spray can cleaner, at lucn im going to get some paper towels and open the pipe and give it a wipe down around the AFM i dont have the tools to get to the one under the airbox, might have to park the car up at home and get the train for the rest of the week.
Proven 6% better flow when you gut them. DONT GUT WORKING MAF's THOUGH!!!!
This pic lets you see the plug better btw.
Follow the lead - where does it go? it's definatly o2 or MAF though and the other end should be around that location somewhere.
Did someone say dash 7s??
Just keep modifying until it's fixed IMO :)
This man nailed it
If in doubt MOAR boost! :woot:
The answer to everthing in life. More boost.
If in doubt - 30+psi and RWD is the answer.
    • I know -_- Oddly enough I went to a car show this weekend and not a single person made any mention of Nitrous... I did have to argue with a know it all that was convinced I had an RB26 head with HKS V-Cam as opposed to a regular VCT RB25 head, but what do I know. I think my HKS oil cap was throwing him off.
    • That seems like a lot more work than just using a second jack under a front tow hook to raise it enough to get another jack under it.
    • They're wonderful when only used to lift your car up an inch so a real jack fits under your front lip. Besides that, I've only ever used them on the side of the road.  We call them widow makers here.  Unfortunately, like I mentioned in another post, ramps are not an option for me due to generally working on my car once my kids are asleep. Cold starts, 4" exhaust and sleep rarely go well together. I honestly find using ramps a hell of a lot more work than what I'm currently doing anyways.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
