-5s will be useless unless you upgrade alot of other things to go with it, you wont be able to run much boost with stock fuel system etc... and will just be laggier
Very true. Look at my build thread if you want to see how much...
google 'bakes' r34 gtr and look at his build thread for minimum mods required for -5's and how ordinary looking (IMO) the results were...and that was with one of the best builders and tuners in australia.
Twin plates are overrated! Jim Berry single plates are where its at! :banana:
Wrong! Jim berry twin plates are where it is really at.
Nope, its dead quiet but with 4600lb clamp it takes whatever is thrown at it so far........ The rattling is amusing for around 3 seconds!
Yep rattle was amusing for 3s with mine....cause is was been made by the spigot bearing :domokun:
so what would everyone recomend
-9/-7 ( on e85) 2000cc injectors, 3+" full exhaust. Upgraded fuel pump(s), 3bar map sensor and haltech/vipec/link ecu. Link ecu would be cheapest.
This will net you 330(-7) to 360(-9) kw on 98 and you may crack 400(-9) if you go for e85. E85 would provide -5 power, without the lag. E85 also requires a ethanol sensor and fuel line upgrades.
TBH, I rekon see if you can go for drive/ride in a -5 and a -9 powered ride and see what suits you best.
Edited by wedge_r34gtr
You could also look at twin gtx2860 or gtx2863 just to throw a spanner in the works.
But just so we're clear - what we're really saying is that you can't just spend $3-4k on an ecu and -5's, slap em on and expect 400awkw. If that were the case, everyone would be doing it. (I wish it was lol)
done mat thanks :)
was busy this arvo :P
benji youll be fine man, dont hoon and dont drive around on a thursday night and youll be fine, our exhausts are similar volume and ive never been hassled and i have black rims :O modified!!!
My exhaust is currently mid 90's since the turbo and cams.... Have a custom one being made that should get me to 88-90 and still flow 500hp :D
My exhaust is currently mid 90's since the turbo and cams.... Have a custom one being made that should get me to 108-110db andflow 800hp :D
FYP :laugh:
Loud exausts are boss.
I just hope my one wont be too quiet!!!
Hope it sounds something like this
yeah im back, been working to much n dont have any spare time
gunna try post a bit more then last month or so, so whats new guys?
keen as for powerplay on sat, gunna be a f**king early morning
Glad your back brah bish! Missed ya!
sorry to tell you your car wont be even close to as loud as that
and every exhaust has a different note, didnt you youtube what itd sound like??
Hahaha at the end of the day it doesn't matter what exhaust you run, the SR will always sound like a piece of shit!!!
Sounds like a tractor..... Fkn horrible engine!
RB or GTFO
This is not HT or BoostCruising
hahaha dont be so mean mat!!
GOD DAMN! look at this beauty
http://www.skylinesaustralia.com/forums/topic/412762-bcnr33-gtr-v-spec-n1-for-sale/
pretty cheap for what it is! only the pricee of a bloody 34r
Plus i had to run to the Central Coast and pick up the oil cooler core to go with the GREDDY block and custom lines.... And front brakes should arrive tomorrow I hope
well DVS jez had a look at my GTR quickly tonight, at idle it was not putting out any error codes, did a smoke test, no leaks besides a small hose that was loose on its fitting quick cable tie and that was sorted, 02 sensors seem to be working fine, unplugged them drove it home, still no boost, the 2 AFM are not reading the same flow rate they are a little bit off so 1 turbo may be sucking harder then the other, ill get the guys that built it to look over it on saturday and see what they think, Jez said next step is to swap my AFM over and see if that makes any difference and to load it up on the dyno and see what its doing under power.
RB or GTFO
Enjoying the sound of an SR is an aquired taste....
I love the grumbling roar!
http://www.skylinesa...ec-n1-for-sale/
Oh my....that is amazing.
But would have to give it a good look underneath at the chassis rails, underbody etc.
Would also like auction papers to confirm its a grade 4 or above.
    • I've got a spare standard box sitting in the garage  I know it will come one day though, but it's driven pretty tamely on the four times a year it gets out...
    • Big question… have you decided on a gearbox? Because it’s going to come… and a gearset ain’t going to do the job.    save your pennies 🤪
    • it was good to see our presence at GTR festival..hope to see more SAU at these events
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
