So Martin where is this track? Can I bring big bird for a run onit? Ha
Aw man if I saw this post in time yeah you could have run.
Had a good and bad day with the car though
Was getting used to driving it then played with tyre pressures and got that sorted then dad had a drive and I jumped in straight after and was having a real go at it when I noticed smoke from under the bonnet then lots of lames from oil fire
Stupid bonnet clips meant we took about 30 seconds not 5 to get bonnet undone and put fire out
Burnt some wiring and coil lead and overflow bottle as well as the bonnet itself.
All because of the stupid plastic line for the oil pressure gauge which got hot and melted spraying oil everywhere
Still can all be fixed, at least it happened on a Test day and not the first event.
    • Been a busy but productive day. Axle and hubs acquired. All fitted up after a bit of modifying. Need to sort out wider mudguards and running light reflector covers but other than that the trailer is gooood to go !!
    • Selling a SMIC for a Nissan Stagea C34 Series 2 and the pipe from the intercooler to inlet. (I believe it is the same R34 GTT, please correct me if I'm wrong) Price: $50? I dont have a photo of the big black pipe that goes from SMIC outlet to throttle body.
    • So the original radiator is leaking now. Looking at getting a fully aluminium one next. Am I correct in saying that the Series 2 Auto Stageas have a separate trans cooler from factory (located in between the rad and intercooler in my previous post/message).   Currently looking at Fenix $460, Blitz $700, GReddy $800, and KoyoRad $740. What are everyones thought on Fenix ( ive read a few comments saying theyre cheap Chinese rebrands etc and how their build quality is... well.. chinese...)  compared to the others? Worth the extra couple hundies?
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
