So Martin where is this track? Can I bring big bird for a run onit? Ha
Aw man if I saw this post in time yeah you could have run.
Had a good and bad day with the car though
Was getting used to driving it then played with tyre pressures and got that sorted then dad had a drive and I jumped in straight after and was having a real go at it when I noticed smoke from under the bonnet then lots of lames from oil fire
Stupid bonnet clips meant we took about 30 seconds not 5 to get bonnet undone and put fire out
Burnt some wiring and coil lead and overflow bottle as well as the bonnet itself.
All because of the stupid plastic line for the oil pressure gauge which got hot and melted spraying oil everywhere
Still can all be fixed, at least it happened on a Test day and not the first event.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
