Yep that's Gaz....
Not many mods, pretty stock.... Soon to have some Jez love!!
Haha he's a champ!
Well if thats pretty stock cant wait to see how mine goes, his one sounds insane!!!
Do you know what Bov he has? HKS SSQV?
Haha he's a champ!
No, just one of the big turbosmart items, whatever the biggest one is! He runs 175ish or something due to EBC, Cooler and Exhaust..... Soon to get some DVS Jez ecu happening!
Hello
Just moved to Newcastle
Looking for some broad minded persons
You have my number :yes:
They sound like a good team
Yes, yes it does!
Only when Mat/Chookie is there.
Cause that's it.
Lol, winning! :woot:
Where's you go?? :blink:
When you need them wheels man?
toilet :D lol
umm yeah i do need them just currently working out how to get up and get them, you being buusy all the time and all ;)
umm might be headed up saturday if your home?
also pub down here this week? martin you can come too if mat gets his shit together :)
toilet :D lol
Charming!
Yeah man been flat out, between work, travelling and random renovations its been hectic!
I cant this week man but wanna catch up with Jake next week so i reckon we all do a pub dinner!!
Ill be away from Friday morning until late Sunday night brah! Carmen is flying up for the weekend so we are going away ;)
CHEATER :rant:
... What's going on over in here, matt i think I've found your home.
It's the Newcastle skyline owner's home away from home :-).
What's everyone up to over the christmas break? i'm heading back over on the 20th for a week.
