Either way sounds good.... I was going to be at the Bathurst 12hr race etc but dunno now so cruise is on the cards....
We can use Chookies car as the turnaround point, itll be upside down in the middle of the road kind of like a roundabout :ph34r:
probably aiming it for the 10 of feb? everyone good for that?
not sure on the route though, i had one planned but i think it needs to be done in winter to avoid summer/beach traffic, but it could be ok by feb?...
otherwise do north end of putty, but not sure on a good turn around point? anyone have any ideas?
I may be able to make it not sure yet
Edited by Chookie!!
10th of Feb is my birthday, birthday cruise sounds good to me :woot:
"you both have a barrel at the end of the street to go around, 1st team down and back wins it"
would it better suit you guys the weekend after?
also chookie, hows the car? find something after the run?
So I've got a job interview tomorrow .....
Field Sales Rep.....
Not sure how I feel about knocking on strangers doors to try sell them stuff. Seems like the type of job thatd get you punched in the face.
Also applied for a style assistant job at kotsra westfield in one of the department stores =D =D
Bahahaha best call!
As long as its not Powercruise weekend i should be fine!
If you knock at my door ill punch you in the face............................................... Even if you are not working :laugh: just kidden Benji
i think the wheel alignment is just way out now?
ill know tomorrow going for another wheel alignment :(
If you've gone really low with the coilovers youre going to need adjustable arms to get the alignment right
benjiman
i have all adjustable arms
just need it aligned cause i can see the front are way out just by sight
Ive painted the inside of the house and finished the ceiling since you saw it :D
Oh, i think i found another cloth, sponge furry thingy of yours.... A blue one?
Good stuff, bet it looks a million times better than it did before, now get those floors sanded
Yeah probably mine bring it with you on the 20th if you can
Hello boys,looking forward to seeing all your handsome mushes at the end of the month. :yes:
Not mine you won't , a face only a mother could love is mine.
I'll be in Kempsy on that Weekend for the first round
http://hillclimbnsw.org.au/cal.pdf
If I miss out so be it but I reckon a good turn around point would be the halfway cafe but if I'm not there my opinion don't count LOL
What's a style assistant?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
