Next cruise whats happening? Noone made a choice yet?
Also who is attending wakefield on may 9th?
I was meant to do something but had a race car to fix at the time
Racecar fixed so can do a written way run if still keen
I did go to Rylstone recently and it's an epic drive but is a 500km round trip
YAWN
Wake up and go tune some epic cars ya lucky bastard!
And yes we know the Newcastle scene is a bit dead, would help if cops werent kents!
yea has been very quite here.. every one is too busy myself included by the sounds of it.
on a good note, my new wheels should be arriving tomorrow, going to pick up tyres from sydney this afternoon and all should be on the car by friday. very keen!
What did you end up with Ant? I forget...
Yeah well the deck is nearly complete and the bathroom is 3/4 done so the house is getting there, that is what has consumed most of my time lately!
good job mat!
the bank just gave me 22.5k for house renos! very keen to get my garage built amongst a whole lot of other stuff!!!
Amazing how quick you can spend $$ when you do a small job.... Work out what you think it will cost then double it :P
haha bloody hope not!! I think the garage and driveway will cost around 10k from the quotes I got.
then were getting a new fence, make a garden out the front where were usually parking, returf some sections of grass, new front door, tile outside under the awning, and possibly a bathroom reno, should come well within the 22k and the house will be so much nicer.
Report back when you are half way through :P
Nah it should be good man! We have been doing it on a budget and its going together OK, slowly though as we are relying on family to help :D
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
