No idea sorry, they sit alright in the Gtr guards though. What rim is it?
I have a spare set of hks cam gears that I'll sell for a special newe price if anyone is interested.
Could be interested in the cam gears mate, it's the next bit on my list. Can you pm me some details please and can go from there?
Or could have a chat about it tonight if your going to the pub?
yeah chat tonight. There at Pauls place atm, but if his home this arvo i'll try and grab and take some photos. There both in excellent condition, except the anodising is fading slightly on the EX cam.
I picked up set of cheap tomei ones, so i'm going with them just to keep the tomei theme going on my head (poncams, retainers, springs etc).
So keen for tonight, work has been the worst and i only started an hour ago, f**k accounts payable, coordinators, and useless team members
this forum needs a like button
Sounds like some Lulz where had after I left
Good night good food and good company,will have to make sure the wife comes along next tiime
EDIT. Thread is up in the events section
Feel free to add/edit it as I can only use my phone at the moment
No Internet makes M.J.H something something
Edited by m.j.h
Wrong thread but maybe?
But nothing happening in here lately so might as well post the spotted cars as well
it was getting quiet in here thought people were dropping off their perches :P
Its the 3rd time in 2weeks ive seen the car, perhaps a stalker :P jks
Me and ant dog are at the snow having a lovely time till sat
Jelly!!!!!!!! :mellow: Have a good time guys!!!!!!!!!
Ill be back whoring up SAU in a couple of weeks, work is consuming me lately............................. :down:
last i saw of my GTR was on a tow truck on the way to Team K Kustoms for a full rebuild.....
This is whats going in her :D should be done by the end of this month then ill come up from the coast for a few meets
CP Pistons
Manly Turbo tough rods 1000hp
Tomei Head gasket
Tomei Baffle pan
Mines Cam baffle
Tomei Oil restrictor
ACL bearings
studs
Tomei valve springs
Gates racing timeing belt kit
Gasket kit
Stock/N1 oil pump
Reimax gears for oil pump
CP Pistons
Tomei Head gasket
Tomei Baffle pan
Mines Cam baffle
ACL bearings
studs
Tomei valve springs
Gasket kit
Stock/N1 oil pump
Not a bad little setup - plenty of supporting mods for when the power bug hits :-)
Edited by wedge_r34gtr
CP Pistons
Tomei Head gasket
Tomei Baffle pan
Mines Cam baffle
ACL bearings
studs
Tomei valve springs
Gasket kit
Stock/N1 oil pump
Sounds like a nice list of parts
What turbo/s you going to run?
Come along on the 26th anyway doesn't matter what car we will only be doing the speed limit anyway
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
