I hope I posted this in the right section but I'm having a slight issue with my car & my wovi inspection, I got a call from them today to tell me that its all good there is no issue with the numbers & the repairs :) the only thing that we can pick is.... your airbag light on your cluster is not coming on like it should!! its should come on for 8seconds then turn off, gee I guess they check more then I thought.
Anyway I've tried searching but I can't find anyone with the same problem or issue I've got. The problem I'm having is it's not coming on at all, I removed the cluster when I got home only to find that there was no light/globe in their at all. So I removed the interior globe from the cluster & put it into the airbag spot to test that it is working however the fault remains & the light still won't come on. I've checked the fuse which was fine but I decided to replace it with a new one anyway, I've also disconnected the battery & re-connected but it still won't work.
When I brought the car their was an after market momo steering wheel on it which I guess is why it was removed, I have replaced it with a standard steering wheel & just recently had the clock spring replaced as the horn wasn't working also to pass the safety inspection.
The horn is now working as it should, but I'm not sure about the airbag other then crashing the car to find out lol.
Does anyone know or have any ideas what the problem maybe or how I can get this fixed without having to take it to Nissan, I'm knew to QLD & I don't know any auto electricians that won't charge the earth like the one I had to repair the horn...
I live near Brisbane so if anyone knows someone that they have used & can possibly recommend, it will be greatly welcomed :) all I want to do is get rego on my car so I can finally take it for a cruise & not just to & from inspections!!
https://www.sau.com.au/forums/topic/402384-no-airbag-light/
i just wrecked a s2 r33 so have abs computer, clock spring, airbags and all sorts of spares. Try a scan tool id possible first but if u need spares let me know.
Did everything go back together as it should once you replaced the clock spring? Did the repalcement have the same letter on it as the one you repalced? They can vary and they are coded by a letter.
https://www.sau.com.au/forums/topic/402384-no-airbag-light/#findComment-6399205
Just wanted to say a huge thanks to Chris for taking the time to drop round & scan my car today, I'm still a little in the dark lol however we were able to sort of narrow it down a bit. Will be definitely joining SAU QLD once I'm finally back on the road :) this site is worth its weight in gold. thanks again
https://www.sau.com.au/forums/topic/402384-no-airbag-light/#findComment-6402304
its not in the airbag electronics we both know that. I suspect a bad connection on the cluster myself.
if I get a bit more time we can look further. today was scan the car and see what pops up.
https://www.sau.com.au/forums/topic/402384-no-airbag-light/#findComment-6402423
Ok after some digging I've come across a photo, now comparing to the back of mine I don't have a wire running from the airbag terminal. I'm suspecting this maybe my issue.
If someone could confirm that there should be a wire connected & if they could let me know where it should be going too as the picture I have, doesn't seem to show the whole of the back of the cluster. Dam I don't seem to be able to upload the picture not sure what I'm doing wrong, anyway there is a wire connected on the back of the cluster to the airbag terminal but I can't see where it is connected to
Edited by mick80
https://www.sau.com.au/forums/topic/402384-no-airbag-light/#findComment-6403112
I seem to have found out what I'm missing from my cluster, the part I'm looking for is the black connector for airbag globe that connects into the back of the instrument cluster, there as two wires that connect into the back of the globe which are also missing. If anyone has one spare that there not using & maybe want to sell or could possibly lend me so I can pass this inspection let me know otherwise I guess I will try & source one from Nissan, thanks in advance.
https://www.sau.com.au/forums/topic/402384-no-airbag-light/#findComment-6403311
Thats some good news if you can help me out Chris, more the happy to drop it to you when your available. I could bring it out to any afternoon or evening just let me know when you might have sometime. I'm really hoping to get back to the inspection place this week & finally get it sorted.
https://www.sau.com.au/forums/topic/402384-no-airbag-light/#findComment-6403664
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
