Item: OS Giken R3C Triple Plate Clutch for R32 and R33 Skylines/ GTR
Description: Used has done low km's still has plenty of meat left on it very nice street clutch for high power GTR's easy to use and super strong. Rated to 800hp +
Price: $1000+Postage
Contact: Ben on [email protected] or PM
https://www.sau.com.au/forums/topic/402387-os-giken-triple-plate-clutch/
Would this work with my r33 gtst?
Got a rb26 and my twin plate alloy button clutch just shit itself
If so, what are the friction plates measuring at?
And how much for postage to 2326
Cheers
Cheers
Yes this will work on a R33 GTST i have put GTR clutches on Gtst before.
The Friction Plates measure: P1=5.25mm...... P2=5.25mm...... P3=5.20
Postage to 2326 = Approx $35.00 - $45.00
I might be crazy to ask but it's a push type right? Comes with throwout bearing and carrier? Willing to ship out of country? The friction discs look new but the plates look way heated. Rebuilt clutch?
Edited by NismoSTune
  • 3 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
