drill out the bolts on your stock wing, they all do that when trying to remove them, its not hard to drill em out the std wing, then you have a CF blade... done.
The thread within the actual blade is threaded, not the bolt itself. Tried drilling it and the bolt still keeps spinning from the inside is you get what I mean?
yep seen that before with those bolts, I drilled it out when it was doing that by holding the bolt with vice grips so it doesnt turn and drill away...
or drill at an angle from different directions so the bolt doesnt want to spin
apparently nissan used a thread lock compound on those bolts...
  • 4 months later...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
