Car has approx 120000 on the shell and box, motor and diff only have approx 2000k's.
Motor -
RB26 bottom end
Tomei Oil restrictor
260 Tomei cams
Tomei cam gears
Kando T-67 25g
Q45 90mm throttle body
Greddy style plenum
Turbosmart 38mm gate
Hks bov
Oil cooler and relocator
100mm front mount
Z32 airflow meter
Nismo 740cc injectors
ISC 52mm alloy radiator
Sard header tank
Blitz dsbc
Hks intank fuel pump
Bosch external pump
2lt surge tank
Power FC
3 inch exhaust to 5 inch cannon
Interior -
Recaro driver and passenger seats
Nardi steering wheel
Quick release boss kit
Apexi EL2 gauges - boost, water temp, oil temp and oil pressure
Pioneer headunit with ipod thingo
Pork audio 6x9's
Power fc hand controller
Turbo timer
Exterior -
Trust front bar
6000k HID's
19x9's front koyas new tires
19x9.5's rear koyas 90%
Driveline -
Cusco 2 way
OS Giken Twin plate
C's Short shifter
Made 441.9hp on 15psi
13,000 ono
Probably more.. Any questions, feel free to ask
Car is located in Mackay 4740
Can text photos.. Forsome reason it wont let me upload photos.
Cheers
Josh
0413 719 366
Edited by collins
https://www.sau.com.au/forums/topic/402462-r33-gts-t-4419hp/
  • 1 month later...
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
