  • Replies 168
haha so funny how 5 of us have 34s :D
yeahhh just wing it id say :)
a guy i work with has a mini turbo that may be keen to come btw, and i may bring my mate paul. will ask the boys tomorrow.
Yeah sweet, just saw your other post Anthony, a heads up should do the job... Just so if ppl do wanna eat we have room :D
I'll hopefully have 2-3 mates with me...
I'm only dropping in on the way to sydney airport, so I prob won't be stayin for any meals etc.
R34 GTR is definatly the best car Nissan have made... The rb engine on the otherhand is not my fav Nissan engine... (Ahh blasphemy!)
Edited by wedge_r34gtr
Could have just left it at R34 :no:
haha yeah thatd be good, be sure to tell her how fun its gunna be for her, with talks of turbos and turbo cooling bonnets etc :P
Nah only rear turbo cooling bonnets, the front turbo is sweet :) and you forgot carbon fibre ha!
called the mattara and have given them a heads up that we will be coming in for lunch around 1pm...
at the moment have a table booked for 20 people which i guess is going to be pretty close? im sure if there is more they can squeeze more tables in etc..
At 12 on the day i might run up and see where they can put us. they mentioned they have a terrace area they might be able to put us in if there are enough people.
Cheers,
Anthony
Cheers,
Anthony
Good stuff! Good organiser :yes: and Good Meet it shall be!! :D
20 should be close enough, if it ends up more then i am sure theyll make it work!
The best being an R34? Haha
:yes:
Pfft, the best Nissan is a 34, but it's a WGNC34!!!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
