I need a pic of the std intercooler piping route on the front passenger side quarter.
Just a shot showing how the pipes go threough the guard, and with or without air box.
Cheers.:aroused:
Enrico - u cant whore this one :)
Found this one on the net, may have a few at home, will check tonight
So there are two 2 and 1/4 inch holes supposed to be chopped into the inner panel then. Mine looked dodgy as like some home job....i was thinkin of doin a fix up job for the new piping....
Any pics of the tubes going through the panel would be great,
Thanks for the replies.....
Enrico.......well what can i say.......
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
