  • Replies 51
I have a 200rwkw S15, how much cash on average are you wanting on top?
ADM, manual, 120,xxx km, black, power fc, greddy profec II ebc, front mount, exhaust, - the usual stuff. Just under 200kw.
PM me if keen.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
