[Vic] Stock R33 Gtr Bov. Stealth Upgrade For R32Gtst,r33Gtst,r34Gtt. Can Post Oz Wide.
Uses the factory sensors? Which are currently the problem?
You can swap between OEM position or closer to chassis. Allows the suspension arms to be a bit more closer to OEM height geometry. My LCAs actually point down now, where as before they were flat. Overall real noticeable difference is I can put down close to 440kW on the street with no wheel spin.
