Hello, listing these parts for my house mate, the Suction Kit suits R32 GTR, injectors suit R32 GTR RB26 (RB30 too?), oil cooler kit should suit any RB ,SR too? (Does fit RB30/RB20/RB25/RB26).
GReddy Hard Pipe Suction Kit - in good condition, comes with everything in photo including pod filters $900
2 x Z32 AFM with plugs - Used, in good condition, mesh unbroken $190 each
Denso 720cc injectors - Used, good condition, part number $380
Tomei Z32 AFM Plug - Brand new in packaging $25 delivered
Oil Cooler Kit + Filter Relocation - Used, in good condition, everything has been thoroughly cleaned. Hoses are -10 size, cooler is 19row $190
Located in Canberra, happy to post anything, please contact me for a postage estimate. Call or text Andre 0403 645 640 or contact via PM. Thanks
you can get the greddy suction kit New from nengun for $1123 shipped and it comes with both the tomei plugs for the z32 afms.
This is $223 cheaper :) You can have the Tomei Plug too, if you like.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
