  • Replies 134
thats true.
i want to take mine to the strip, just saying that any longer than that in my car i'd need to take a book while its bouncing off the limiter for next 500m :)
If a particular model (Supra, Evo, Skyline, Commodore incl HDT and HSV, Falcon incl FPV) of car gets 10 or more entrants, there will be a Fastest *insert model* trophy.
Supra's are on 9 so far
Commodores are on 7 so far
Skylines are on 6 so far
This event will rock your socks off. Make sure you go folks.
I would love to roll from ACT to Cooma with you all on the day !! :D
If Kats GTR is on the strip we can cheer her on big time.
Get your Skylines lined up for this one.
Below is the entry list for the first 50 entrants.
HOLDEN COMMODORE VL
MAZDA RX7
TOYOTA SUPRA
HOLDEN COMMODORE
MAZDA RX7
MITSUBISHI LANCER EVO 8
TOYOTA SUPRA
TOYOTA SUPRA
HOLDEN COMMODORE
TOYOTA MR2
HSV 427
TOYOTA SUPRA
HOLDEN CALAIS
TOYOTA HILUX
CHEVROLET CORVETTE Z06
LAMBORGHINI GALLARDO
MAZDA MX5
NISSAN SKYLINE R32 GTR
HONDA CIVIC
HOLDEN VG UTE
FORD FALCON XR6 TURBO
HOLDEN COMMODORE SS
NISSAN SKYLINE
MITSUBISHI LANCER EVO 5
SHELBY MUSTANG GT350R
NISSAN GTR35
HONDA S2000
FORD FALCON XW GT
NISSAN 180SX
TOYOTA SUPRA
VOLKSWAGEN GOLF CABRIOLET
HOLDEN TORANA SLR
SUBARU WRX
FPV GTP
FORD FALCON XT
AUDI S4
TOYOTA SUPRA
FORD FALCON XY GT
TOYOTA SUPRA
PORSCHE 911 TURBO
TOYOTA SUPRA
LAMBORGHINI MURCIELAGO LP640
BMW X5M
JEEP CHEROKEE
TOYOTA CELICA GT4
TOYOTA SUPRA
NISSAN R35 GTR
HSV XU6
HSV CLUBSPORT
PORSCHE 930T
Supra's have just hit 10, so they now have their own trophy for Fastest Supra
If you are looking at or even thinking about entering the Shannons Insurance Snowy Mountains 1000, not would be the time to do so, as entrants spots are filling up. Please email [email protected] for entry forms and all other relevant info
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
