Hi guys, car got rear ended on the hume highway on Tuesday, write off. Few pieces I have to get rid of now.
Full set of bilstein suspension, $200 neg (rough).
R32 Rb20 TPS $10
R32 GTR GTS4 Slave $10
R32 RB20 Bottom half air box $Free
R32 GTR Tripple cluster $20
R32 Fog Lights, not sure if these fit GTR or GTS4 or GTST, welcome to have a look if you like. (Rough, clip broken etc, brackets included) $20
Old school HKS Boost guage and crappy bracket $20
R32 RB20 (Maybe RB26) Air con condensor, backet, adjuster pulley and belt all included! $45
R32 Ashtray (Think that rust wipes off) $10
Another 32 to the wrecker.
I would much prefer pick ups Sydney only, but just double check with me first about postage if its important.
Message me 0434284396
Edited by ima_slap_joO
  • 5 weeks later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
