Any auto store such as Superheap, Autobarn etc will have mesh. You'll have to cut it to fit but that's you're best bet. Just don't get some ugly colour like anodized blue or something like a Holden:p
^This!!!
And yeah Supercheap etc have it.... I will probably do mine at some stage so if you do have a go make sure you take pics and post them up for us ;)
My cooler is all black but after getting a large rock breaking my windscreen i would be worried about the same size thing hitting my Plazmaman cooler, so mine will be more for protection :)
Yeah not a bad idea! We were going to do a mates Silvia first so i would have had practice but it was in a pile up and is now in getting repaired........ I wanna see someone have a go before trying lol
i did mine just bought the mesh from auto barn cut it with side cutters about 30mm bigger all the way round the bent it over and cut out sections to make tags and sikaflexed it on.works great.i got black and painted my cooler black and u cant really notice its there.
dont buy the shit at repco its rubbish its thin and bends easy,unless they have changed there suppplier recently.
I got it because it was thin, it has better flow than the thicker stuff, and I found how it bends easy was a good thing as you can easily form it and shape it around corners.
Me too, so easy and cheap!
I was wanting to do the same...but the pattern, thickness and quality of the stock intercooler mesh cannot be matched. Everything bought at Bunnings, Supercheap Auto or Autobarn sucks. I decided to leave my GTR naked.
You can get some cool waterjet cut stainless or alloy and powerdercoated mesh from usa , two custom sheets i just priced shipped is around 150 and its not the thin crap or cut up its full size sent priority mail
two places in the states have at least 20 patterns and ? About how many colours , some is ghetto SUV , 300c stuff but the stuff I found is like nothing else around
Stainless steel security mesh, comes in different size weaves and is strong enough to stop a thief... And is already black, costs about $30 for an offcut, mine has been on for three years and looks just as new...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
