  • Replies 180
Posted Images
Brisbane/Gold Coast V35 Owners Cruise:
Date: Aug 18th 2012
Cruise Details: Brisbane to Point Danger Light House, Tweed Heads
Route Length : 104km
Meeting Place 1: Mc Donalds @ Springwood at 9.30am for a 10.00am start
Meeting Place 2: BP @ Yatala at 10.15am for a 10.45am start
Final Stop: Point Danger Light House ( anticipated reach time at 11.30am) Lunch and then return to Brissie or as per crew suggested plans
Confirmed List:
1. Tony350 (+Victor)
2. 4evershiva
3. FlyingEL
4. Sheldon
5. Vthirty5
6.Kolossus +1
7. Spencer
8.n15m0
9.Bradstreet
Edited by shiva
Yet to see one in the flesh! How do you like your V36?
I absolutely love it, I found it by accident on carsales. There are a couple of things I need to sus out. Hopefully you guys might be able to help me I know it's a v36 but any info is better then none.
Edited by Bradstreet
Date: Aug 18th 2012
Confirmed List:
2. 4evershiva
3. FlyingEL
4. Sheldon
5. Vthirty5
6.Kolossus +1
7. Spencer
8.n15m0
9.Bradstreet
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
