Shiva, i'll try and put this into perspective for you.
To change the colour of your car completely, you need to paint inside the doors/boot/engine bay etc. That means they will need to take out the engine and interior. Thats a lot of labour, and the whole job could cost between 5k - 10k. They might also f**k your interior in the process and not put shit back together properly. In my opinion its not worth it. Your better off selling your car and buying the colour you like.
Your other option would be stick as close as possible to black. ie just change to black pearl over the top and a new coat of clear to freshen your paint up. It will look brand new when its done, the only thing is the pearl wont be in the engine bay or inside the doors.. Nobody would even notice that. You could probably get this done for around 2k for a good job. (FYI you could probably get it done for less but it will show...)
Also from your questions, it sounds like you dont have any painting experience so i dont reconmend doing it yourself.
naah...i am not doing it myself...i dont wanna spend 5k on this...i did check some picture of matte black wrap...but it doesnt look that great on a V35.....shud i just go detailing on the interior and exterior to get away with swirls and minor scratches and few stone chips....it would cost me $700 to $800 for a good job of that....
If you want a really good detailing job check out http://arkbarrier.com.au/ they basically polish the crap out of your car then coat it in the thin layer of glass. Looks mint, plus water just runs off it.
I would also question a $2k figure for just an 'exterior surface' respray, especially if you want a pearl finish.
If done properly there is a lot of work involved.. removal of door trims, door handles, removal of windscreen/window rubber seals. headlights, bumpers, rear badges, tail lights, door bump strips, etc, etc..
I would estimate closer to $4k.. $2k for the paint and another $2k for labour.
If you just wanted a standard 2 layer paint (not pearl), you might be able to cut the paint cost a fair bit.
If you existing paint is flawless (no stone chips, deep scratches, etc), you might even get the labour a little cheaper.
unless you happen to know someone in the business and can do a 'cash in hand' deal..
Ark Barrier does not crack, bubble, flake, peel, delaminate, come off or discolour, as long as the temperature remains below 700 degrees℃.
If your car was exposed to 700+ deg C, you have other things to worry about.
which i do thus my price..
My V35 recently had a full respray, no colour change, just respray original colour. Costs 6k+.
If your talking about a surface spray only, i.e. no sanding back to metal and priming before applying new coat of paint, then 2-3k is probably what it would cost. If you want a proper full respray, you will be looking at north of 5k.
Envy me, i am family friends with the painter out the back of my work and i get everything done FREE unless he does "a big job" i'd give him cash or a few cartons. Just got my Front bar, Boot lid full resprayed and stone chips touched up last week completely free.
Will he do it for fellow skyline owners?? :)
My front passenger side door was resprayed by a previous owner (no idea why), and the colour doesn't quite match.. irritates me every time I see it..
I can talk to him, it depends how much work you want done. My mate wanted heaps of shit done and he just told him to go to a paint shop. He's a bloke you really need to get to know for him to do free stuff for you but if it's only a small job he might be happy with a bit of cash. He does A+ work i've very very happy with what he did for me.
No probs.. not sure when I would be down your way next anyway.
Don't know if the best way would be to match the colour of the rest of the car and respray the door, or match the colour of this door, and blend the colour on the adjoining panels..
matte black wrap quote = $5,200 + GST....thats a rip off.....have to rethink as to what needs to be done
Matte is hard to maintain...you'll be washing your car every weekend so you don't get dirt and grime build up. That's if you really love your car lol.
Edited by Marshan
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
