The President is also (IMHO) one of the worst styled luxury cars money can buy. Truly awful :D
Celsiors are nice, with a sensible kit and decent wheels. Trouble is, more often than not they end up with some monster kit, wing's bigger than most planes, drainpipes...no sewage pipes for exhausts and massive wheels at a ridiculous camber angle squeezed under monster fenders....:)
https://www.sau.com.au/forums/topic/40443-vip/#findComment-832788
uh no...:D
VIP strickly speaking mostly sedans and vans which enables you to fit a bigass sound system and still have your mates in the back to cruise around with you. Not to mention it's suppose to be a slug, heavy and with very little performance thus it's a show car. Which is the reason for it's popularity with bitumen scrapping bodykits but they seem to think they can still drift the car which results in an even better bodykit, one with a damaged/torn front bar...mostly entered in SPL comps.
https://www.sau.com.au/forums/topic/40443-vip/#findComment-840014
Dave: now VIP vans is something I would consider myself...more practical, more space and looks so much more better then a sedan when dumped on 20". A van would be no heavier then a sedan, plus it has a greater sleeper effect...with a 4WD version and the fact they are now front engines tuners have been able to slap on S/C anc T/C for some mild boost. My choice a Hybrid Estima, black of course, 20" with a nice kit :), the guy who installed my alarm had his new demo white Alphard at the shop...very very nice. Because it was a shop demo car it had every freaking alarm possible and security devices install on the market to demonstration to the customer. He joked if this van could be stolen via means of entry the theif is a genius.
https://www.sau.com.au/forums/topic/40443-vip/#findComment-841169
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
