I have my Power FC for sale out of my R34 GTR with the hand controller. It has less than 10,000kms on it. I have gone with a Haltech Platinum pro to support my new E85 route, so I no longer need this ECU. This ECU is the L-Jetro normal version Power FC with the need to still run AFM's.
It has a tune of 380kwatw installed on it, which was tuned by Racepace. It could be easily installed at home by anyone to get it to the tuner, but I would not accelerate anywhere what so ever until it is on the dyno.
$700
Call Simon on 0408 766 268.
I've just done a bit research on this and seems you can do it with a few tweaks with the AFM's and O2 sensor with bridging the wires in the 26 loom or something, but yes it has been done many times before. The RB26 Power FC though does not support the Variable cam timing (VCT) of the RB25, but this is not a huge concern for power levels and really derive you of HP.
VCT is only a means of having an engine fuel efficient whilst driving it casually, whilst being able to get power out of it in the mid to top end. If you tune it without it, you will still be able to achieve the same HP level.
I am assuming you have the original RB25 ECU though, because you will need it for the Power FC to plug into.
These 2 SAU mebers have some very good knowledge on this subject, so feel free to ask them how to do it if you end up doing this mate.
paulr33
The Mafia
If you are an ECU Noob, dont worry too much, there are many good people around who can help you with this.
Where abouts do you live Bill?
Cheers, Simon.
  • 1 month later...
  • 2 months later...
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
